tab control to drop down menu
hello, experts,
quick question for your quick answers...
i am displaying multiple graphs in my vi...each within its own tab.  i think it'd look much better if i can display them individually using a drop down menu.
is there anyway i can do that?
thanks for helping,
ck
(3,762 Views)
You could use an enum control wired into a case structure.  For the different cases you could set a graph to visible when it was selected and it would be invisible if it was not selected.
I can wire up an example tomorrow morning if you need it.
Kenny
Kenny
(3,760 Views)
kenny, that'll be super...please show me with your sample code. thank you!!
(3,754 Views)
Have a look at this vi.
I used a tab control with transparent colour.
Message Edited by becktho on 03-01-2006 10:03 AM
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,754 Views)
See if this works for you.  If you have any questions on it let me know.
Kenny
Kenny
(3,739 Views)
how do i set to "transparent color"? I couldn't find the setting anywhere.
while i am at it...can labview set the percentage of transparency?  may i use it to create a see-through menu?  it'd be great if i can see the background as well as the menu.
please advise,
ck
(3,729 Views)
Hi
Open the tools windows and set the color - in the color dialog select the "T" top right of it.
Just have a look at the pictures:
In the second picture you don't see the tab anymore - just the squares of it when you move the mouse into the tab area.
As fas as I know, it is not possible to set different values of transparency.
Thomas
Message Edited by becktho on 03-02-2006 07:10 AM
Using LV8.0
(3,721 Views)
