tab control strict typedef hides controls
"Has the issue of no typedef tabs been resolved in LV7? I am modifying a LV61 vi and severely broke the panel trying to convert a tab to a typedef. I was able to customize, however there was a compile/save error and all the embedded controls on the tab pages became hidden and un retrievable."
Jim Henderson"
(3,368 Views)
Jim,
Could you post the VI that shows this problem? I couldn't reporduce it with 6.1 nor 7. Attached is the VI I used to test this. It has a strict type tab on its front panel with couple controls on it.
Zvezdana S.
(3,368 Views)
Zvezdana
In my disgust, I had deleted all copies of the offending vi. I believe my problem must have been, primarily, a corrupted compile/save.
Jim
(3,368 Views)
I just add one control into this table, then immediately turn this typedef into error.
My question is why can not add any control into the table?
(3,016 Views)
