system halt after my program run
infoI make a program by LabVIEW 6i. The program function is that firstly it get data from OPC server by network, secondly to send command by RS-232. But the program do not run correctly. some information as follows:
1. computer: advantech industrial PC, CPU: P3-800(intel), memory:128M, HD:20G, display memory:4M(ATI), net crad: 3Com(3c905,10-100M)
2. system: windows NT4.0 workstation with SP4 (chinese), LabVIEW 6i
3. OPC: server: citect.opc (citect is automation & industrial software),
client: labVIEW.opc
4. some phenomena: when the program run after 4-5 hours or 10-12 hours, system halt and show that visual memory is shortage(visual memory of system is 160M).
I do not know why it is, need you help.
thanks
in advance.
Liu Weixing
2001/10/23
(2,394 Views)
Can't open your attachment because it's not a VI but I would look at array construction and references always being created and never closed. Good luck.
(2,394 Views)
Dennis,
He's zipped it up. Unzip it, and you'll get a .llb. Open the .llb, and open the main.vi.
Mark
(2,394 Views)
hi
can you tell me your e-mail? I wish to get you help.
Liu Weixing
2001/10/25
my e-mail:wxliu163@sh163.net
(2,394 Views)
Two suggestion you might try:
1. Update your video monitor to the latest version.
2. Put a small delay (around 10 to 100 ms) in all your For and While Loops (including sub VIs). To create a delay, use the the 'Wait' sub VI in the Time & Dialog sub palette. This will force LabVIEW to pause momentarily and let Windows do other stuff....
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,394 Views)
