08-19-2021 04:59 AM
Bonjour à tous , j'ai besoin de votre aide
J'ai construit un tableau 2D avec des chiffres et j'aimerais l'afficher dans dans un fichier texte mais sans tabulation , je veux juste séparer les deux colonnes par point virgule et sans espace.
espace entre chaque données du tableau est-ce possible de les supprimer ?
merci à vous.
Solved! Go to Solution.
08-19-2021 06:07 AM
Hi asmae,
@asmae97 wrote:
I have built a 2D table with numbers and would like to display it in a text file but without tab, I just want to separate the two columns with semicolon and no spaces.
space between each data in the table is it possible to delete them?
Yes.
Use a better format string!
08-19-2021 07:17 AM
merci infiniment GerdW.
j'ai une autre question s'il vous plait , je veux rajouter un titre à chaque colonne de tableau 2D.
je sais pas si vous connaissez une fonction qui va m'aider à faire ca?
08-19-2021 07:53 AM
Hi asmae,
@asmae97 wrote:
I have another question please, I want to add a title to each column of 2D table.
I don't know if you know of a function that will help me do this?
It really would help when you write your questions in English when you are posting in the English section of the forum. (There is a dedicated regional board for French discussions…)
To add "titles" to a 2D array you could add/prepend an additional row!
Or are you talking about a table indicator? This one offers properties to set row/column headers…
08-19-2021 08:42 AM
I have an array 2D table, the problem is that I can't add the title automatically to each column of this table
08-20-2021 02:01 AM
Hi asmae,
Why can't you add/prepend column titles?
What is an "array 2D table"?
What have you tried?
Where are you stuck?
Why don't you attach an example VI?
08-20-2021 04:00 AM
in both cases (2d array, table control) you need to convert the data from double to string
08-24-2021 09:13 AM
please can you send me this programme , thank you so much
08-24-2021 12:53 PM
