supply voltage for hall sensor
hi!!
i have ordered NI 6008 DAQ, now my question is that, do i need external supply voltage for my hall sensor or the hall sensor gets the power from the DAQ itself?
thanq
Every Expert was once a Beginner!!
(3,646 Views)
Do you have any further details about your hall sensor?
The USB-6008 does have a +5V output (driven from the usb) which can supply up to 200mA.
(3,644 Views)
(3,641 Views)
Accepted by topic author PROing
From the datasheet, page 4 shows supply voltage as 5V, supply current as 5.6mA
So yes, you should be able to connect it directly.
+5V - pin 31 --> +Vcc
GND - pin 32 --> GND
Vout goes to one of the Digital Inputs pins.
(3,637 Views)
small clarification... why should i connect Vout to the digital pins, because i am using linear hall sensor which is to anolog. pls tell me am i correct?
(3,632 Views)
Sorry, yes you are right. It should go to an analog input, not digital.
(3,630 Views)
