suggestion for pH adjustment alogrithm
Hi, here is my code for judging pH and adjusting pH value using state machine.
I only finished the cases when pH >7.5, I havent done the cases for pH<7.5.
I understand its very akward because it lacks of real control alogrithm; But I really dont know how to program a controller to relate time and pH value together.
In the VI, you will see I adjust pH by opening/closing relay board which further drives valve to open/close to let electrolyte flow out/stop.
We will do experiment to determine the time for opening/closing valves... It will invlove a lot of work and I am aware of it.
Any suggestion regarding programing technique, bug, etc will be appreciated. Thank u!
p.s the BEi delay VI is provided by one of NI forum adminstrators.
(2,699 Views)
I found one problem myself,
in the case of ''start DAQ'', I want the VI to take measurement for 5 seconds and stop, then it can calculate mean value. The mean value will be used for later cases.
The problem is the start DAQ keeps running, when 5 seconds is reached, the mean pH value is calulated but the Vi is stilling reading data...
(2,691 Views)
Accepted by topic author godpaul
  Hello
 -You could wire the stop input in the DAQ assistant and the stopped output to the end condition of the loop to stop the acquisition after 5 seconds.
Regards
(2,661 Views)
