03-05-2012 01:03 PM
I've worked with LV for several years and am now seeing a strange problem, on occasion, when I create a subvi, I open the connector pane and assign all the connections as usual and save it, but when I drop the subvi on a block diagram, the connections don't show up, either on the block diagram or on context help. But the connector pane is complete. Why is this happening?
Solved! Go to Solution.
03-05-2012 01:55 PM
Please post your code, if possible.
03-05-2012 02:09 PM
This is a Known issue the CAR is 318144
I'm hoping this fix made it into 2011SP1 But I haven't read the release notes yet
03-05-2012 02:23 PM
Thank you for the CAR info. I was wracking my brain trying to figure out how to "post my code".
03-05-2012 02:31 PM
Not a problem- Except, the CAR is not in the readme as fixed in 2011 SP1
08-17-2012 07:03 AM
Saw this bug today. Was not fixed in 2011 SP1.
