subvi Issues with LV PDA 8.0
    I am currently working on the VI i've attached and  on the first sequence structure I have a subvi called write Header PPC, inside that subVI there is anoter subVI called comments PPC. I right clicked it and did a subVI Node setup and checked on, "show front panel when called".. now this is where the problem arrises..
the subVI loads and the color change in the subVI tells me it did call it and load, but there is nothing on the screen. SO for a moment I thought, i hadn't scaled it properly for the screen, so I wrote another VI that just calls it (called test.vi) and it is proportional to the screen..so I am not sure how to debug this issue, any help would be greatly appreciated.
thank you,
(2,748 Views)
LLB's are a bit out of date for LabVIEW 8 and its difficult to make sense of all the VIs you have in there. If you are building these VIs for your PDA, then you must be using a project, since a project is required to create a build script. Would it be possible for you to post your project or to post a seperate project that is simplified and clearly demonstrates the odd behavior. I'm most interested in the settings you are using for your build script, such as whether front panels are being included.
Kind Regards,
E. Sulzer
(2,733 Views)
I am sorry, i fixed that issue already. I made a new post about about this new problem I am having.. Not sure how to go about deleting this post.
(2,729 Views)
