04-11-2017 03:17 PM
Hey all,
I have a subvi in a project that I would like to insert into a subpanel. To complicate things, the vi is called directly elsewhere in legacy code that can't be easily changed (simulated by the false case structure at the bottom). Is there any way I can still call and run the subvi in the subpanel when it is loaded elsewhere?
Solved! Go to Solution.
04-11-2017 03:37 PM - edited 04-11-2017 03:43 PM
04-11-2017 04:24 PM
