11-06-2012 10:15 AM
I am using LabVIEW 11.0 version and I am starting to think this may be more of a bug, but wondering if there is something I am doing wrong first?
From time to time I will connect an item from the front panel to the VI connection block. Then I save the program and go to place it as a subvi and the linkage no longer works.
See the 2 photos below for a better explanation. In the first photo, I have zoomed in on the connection diagram and you can easily see I have selected the "Channel Chosen" String indicator to be wired out in a higher level program. in the second picture you can see that the new connection never appears when I go to run it as a sub VI. Any ideas what is happenening here. From time to time I have had to undo all connections in the connector block and redo them. Other times I actually have to change the shape of the connector block and redo and then it seems to take. Is this a bug in the LabVIEW 11.0 code or am I missing something.
Lastly I do apologize for the big black boxes but I have censored anything that may remotely be considered company proprietary.
11-06-2012 10:17 AM
Sorry, no attachments. It would be far better to post your code than simply posting pictures. Either way, you didn't include anything.
11-06-2012 10:20 AM
Sorry I thought the pictures were posted, this doesn't appear to be an issue with code on my end so much as it would either appear to be a bug or me not knowing how to properly update the icon linkages. It has happened to me a few times before. Usually it occurs when editing existing SubVI's
11-06-2012 10:27 AM
Are you working within a project? Is it possible you have more than one copy of the Channel Config VI on your system and you have a cross link issue?
11-06-2012 10:48 AM
I don't think that is the issue, as to edit the channel config sub vi all I do is double click and open that particular one. So I am quite certain I am changing the correct one. This is not the first time something like this has happened to me.
11-06-2012 11:04 AM
Actually, this is a known issue R&D did some work on. I don't recall if SP1 fixed it but 2012 does not have this feature
11-06-2012 11:14 AM
Thanks Jeff, glad to know this is a known issue, is there any known workaround or way to refresh it that doesn't involve wiping clean my entire connection diagram and starting over. As for 2012, yea I put in for it but the company was too cheap!
Adam
11-06-2012 11:29 AM
saving closing and reopening the file usually does the trick
11-06-2012 11:54 AM
I have seen this issue with 2011 SP1. Have not worked with 2012 enough to actually say anything.
