01-04-2012 10:30 AM
I just had labview 2010 installed on one of our lab computers and after installation, the front panel of all my VIs has a strange look. There are vertical and horizontal lines (that were not there before), around my boolean icons, tabs, boxes etc. there is almost a texturized appearance. I've had it re-installed and this problem still persists. Everything is functioning just fine, it's just an aesthetic issue. We've done the exact same install in many of our other lab computers and they look just fine. I've tried looking through the settings on VI appearance and there doesn't seem to be anything that I can find that would fix this. Has anyone seen this before? Any suggestions? Below are some pictures of what I'm seeing.
Thanks!
01-04-2012 10:41 AM
Check your graphics setting. It almost looks like your are using very low bit depth and the OS is doing some dithering.
This can happen if your graphic driver is incorrect for the hardware.
01-04-2012 04:35 PM
Thanks for the suggestion. I looked and I'm at 32 bit color setting (max for my computer) and I tried updating my graphics driver (NVIDA Quatro FX 3700) and that sadly didn't fix the problem. The strange thing is that previous to installing 2010, we had labview 2009 and it was just fine. Any other thoughts?
