Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
stop SubVI from main VI using event
Hi all,
Here is my problem. I want to start a subVI from my top level VI. I want to stop the subVI using an event generated from the top level. I dont know why but it doesnt work. Any suggestions?
I use Labview 2011.
thank you.
Cedric
(3,789 Views)
Becuase you never exit your Start event case when you call the subVI. The event case cannot exit until the subVI completes. You need to dynamically call the subVI and not wait for it to complete. You can use the "Start Asynchrous Call" VI to start the subVI.
Also, the Wait 200 you have in the loop with the event structure is not necessary. The loop will be idle and only run when an event is fired. You also don't need the timeout event in your main.vi. It is doing nothing but consuming resoureces since you have no code in your timeout case.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,788 Views)
Hi Mike,
Is there another solution without using the ''Start Asynchronous Call" function?
thank you
Cedric
(3,770 Views)
I worked around another solution and I implemented a Producer/consumer strategy (see attached VIs, Labview 2011). There is something very strange because when I press 'start' and then 'Stop', it works well, the second time I press the 'start' then 'stop', it works well. But the third time I press 'start' then 'stop', nothing appends! The event seems not working properly because the SubVi doesn't output the text 'END'.
Any ideas why there is such behavior?
Thank you.
Cedric
(3,765 Views)
I am not sure what is going on with your VIs. That is some odd behavior. I am curious though, why don't you want to use the Start Asychrous Call?
Also, I generally don't handle events for controls on other VIs. For what you are doing I would use user events.
Mark Yedinak
LabVIEW Champion
(3,755 Views)
Hi Mark,
I dont want to use the 'Start asynchronous call' because I want to get an output from the function. Using such call, I have to use the 'wait asynchronous' function which is not adapted to my application because It is quite complex to implement.
If you think that the 'user event' is better adapted for my case, do you have an example of such implementation?
thank you.
Cedric
(3,733 Views)
@Cedric51 wrote:
Hi Mark,
thank you.
Cedric
You can always get data from a VI that was started using the Asychronous Call by using queues, notifiers or user events to send data out.
Mark Yedinak
LabVIEW Champion
(3,706 Views)
