stand alone application (exe) not found in Build specifications
hi all,
I have installed labview professional 2017 on an off-line stand alone computer(no internet connection).
I activated the license.
I opened a new blank project and when I press right click on "Build Specifications"->"new" - I see only "Source distribution" tab.
 I don't see all other possibilities. like exe or installer and ect...
can anyone point on what can fix this?
thanks ,
Eliran
(4,587 Views)
Hi Eliran,
is the AppBuilder activated?
Did you check the NI LicenseManager?
(4,584 Views)
I am kind of new in labview.
when I open the NI LicenseManager I can see that the " Professional Development System" in activated in green.
under "Add-ons" I see "Application Builder" it seems like it is not in my package, because it is an add-on.
do I have to have it?
(4,581 Views)
Hi Eliran,
you have to activate the AppBuilder too before you can use it.
Usually the license for the PDS includes the license for the AppBuilder:
(4,550 Views)
thanks GerdW 🙂
you are correct.
when I installed labview I got activation code for labview , but I didn't receive activation code for the add-ons
apparently you also need to receive activation code for the AppBuilder
and all the add-ons.
after you activate them also. you can see all the properties of the "Build specifications"
(4,512 Views)
"apparently you also need to receive activation code for the AppBuilder"
Not necessarily. If you have a license for LV Professional, you can just leave the AppBuilder field empty, and only fill the LabVIEW license field. The app builder will get activated automatically.
(4,508 Views)
