06-26-2015 05:32 AM - edited 06-26-2015 05:53 AM
Dear group members - as i am trying to build a stand alone application , i ran into this problem : "Error 7 occurred at Open File+.vi: Open File" (L'erreur 7 s'est produite à : Open File+.vi:Open File)
when i select continue i get this error message: "Error 7 occurred at open/create/replace file in Write spreadsheet string.vi->Write To Spreadsheet File (I64).vi->Mono Com Write ini.vi->mainVI2.vi"" ( "L'erreur 7 s'est produite à : Ouvrir/Créer/Remplacer un fichier dans Write Spreadsheet String.vi->Write To Spreadsheet File (I64).vi->Mono Com Write ini.vi->mainVI2.vi" )
i didn't get what's the problem with this vi, i have no problem running my VIs
Can any one here help me out ?
here is the project :
06-26-2015 07:22 AM
the second error was due to a wrong path i inseredto the mono com write. but i still have this one: "Error 7 occurred at Open File+.vi: Open File"
Possible reasons:
LABVIW: file not found. Or
NI-488: non-existent board.
any ideas pleaaaaase ??
i can't even figure out which file is missing
06-26-2015 05:29 PM
Neither can I. When I opened your Project, there were no VIs present on the top level. The Build Spec refers to a Mainv12, which I finally found buried in the folder Interface 2, but when I tried to open it, there were multiple missing VIs. I notice you have an Interface 2.llb -- is this the same as the VIs in the Interface 2 folder? If so, try getting rid of the .llb (at least for the purpose of sharing your code in the Forum) and re-post your code. As it stands, when I open your Project, virtually every entry is marked "Warning: has been deleted, etc." The fact that so much is "missing" means that I can't easily see/understand MainV12, hence can't guess where the File Not Found error is arising. Sorry.
06-27-2015 08:15 PM
