splitting the income data from Arduino in labview
@0636079234 wrote:
Please I need the lm35 heat sensor on labview and  arduino with code
Please create a new thread for this new topic, and be more specific about what your question is.
Message 11 of 14
(623 Views)
... and don't place plain text into code tags.
Message 12 of 14
(620 Views)
How can I start communication with HC-SR04 ultrasonic sensor with Arduino on LabVIEW(visa).
I need an example with the programming code
Message 13 of 14
(606 Views)
How are you sending the data from the Arduino to LabVIEW?
You seem to have 16 different pressure points (4x4) + a temperature.
If you send 1 1D array of 17 data elements, then you can split it down into your 4x4 and your 1
What you are currently doing is processing 4 data elements every loop (and 17 / 4 =! integer number), so you either need to send 4 temp readings.... ; process the whole data set in 1 go or handle the temp read back better.
You should probably setup the termination char on your serial port and read bytes at port instead of a byte count too. (this may be your main issue, if you are reading too fast).
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 14 of 14
(602 Views)
