splitting serial data from multiple sensors recieved from arduino in Labview?
That is the Baud Rate, which is the rate that bits are sent in a message.  The question was how often does your Arduino send messages.
Message 11 of 13
(1,475 Views)
Actually I am sending 120 bytes of data from arduino to labview via serial port every 100ms at 57600 baud rate.
when I am sending more than 120bytes the data updation in labview is very slow.the looptime in labview is 200ms.
Message 12 of 13
(1,120 Views)
And what does this have to do the the issue the OP had?  If you have a problem, start a new thread.  You will also need to supply some code for us to help you debug your problem.
Message 13 of 13
(1,112 Views)
