split the characters based on the length
@OATTelecom wrote:
how to set the display format of the U8 array to binary, 8 digits, pad with zeroes.
Make sure to select the array element, not the array container. 😄
Message 11 of 14
(865 Views)
Thank you , but I want to use bit for encoding
ex.
String "Hello"  => change to binary bit ("10110010" "....." "....." ...) then  split each binary to encoding.
Message 12 of 14
(853 Views)
What exactly do you mean by that?
Jeff's and Altenbach's examples have given what you asked for.  If this isn't what you actually want, then please be more precise in explaining what you want your end result to be.  Even include a VI that contains the data saved in a data type that matches what you are looking for.
Message 13 of 14
(846 Views)
If you want the bits as an array of booleans, use "number to boolean array".
Message 14 of 14
(840 Views)
