05-31-2009 04:21 PM
I am trying convert a speed function into acceleration i have added a sample of the program. I tried some of the derivate function but i dont seem to get the results as i calcutaled it should be between 0 and 20.
The signal i want is from RPM then i tried to derivate with just the derivate function thatcan be found in he simulastionfunction then i triedto use the other to derivate function. And i just used and input and output.No time function added.
Someone have atip how to make it showme me acceleration function in a graph?
06-01-2009 04:26 AM
06-01-2009 04:57 AM
oI will try to use the derivate.vi you recommenedbut the problem is cani use the time function i made to put that directcly into the dt? if not then what?.
I am new at labview so just bare with me:9
06-01-2009 05:00 AM
06-01-2009 05:12 AM
ok. I can try to xplain what i am trying to build here.The ysstem you are looking at is a hydraulic transmision software. It gets inputs signal from 2 presure meter 1 THACO meter and 1 potensiometer. From that one can have a auto function of regulating the handel of the pump system .
And the pump system at the and is driving a swingwheel
What i am trying to find out is how much acceleration it has when it reches its max point which is 1470 RPM and when we slow it down tillit stops.
So do i need to set a input on dt for this
06-01-2009 05:23 AM - edited 06-01-2009 05:24 AM
06-01-2009 06:55 AM
06-01-2009 08:01 AM - edited 06-01-2009 08:03 AM
06-01-2009 09:07 AM
06-01-2009 10:04 AM
