02-05-2010 02:52 AM
i am using sound card to get my signals. The program was made in LV vsersion7.1.
Now when i modified and started using 8.5, i got change in signals received.
Initially i used to get signals till value of 150-190 to zero but in 8.5 i get 1 to 1 peak.
When i checked th icons call two diffrent lib lvsound.* and lvsound2.*
And also in 8.5 when i receive signal for 1 second i get samples equal to sampling rate (11025 samples if rate is 11khz)
and in previous one when i programme it for 11025 samples it takes nearly 12 secs instead of 6 sec.
Can anybody explain this diff,
is there any diff in usage of both the libraries.
All inputs are welcome,,,n thanks in advance/....
02-05-2010 03:29 AM
02-06-2010 11:40 AM
That may be a case but i have a problem that i am getting entirely diff results using both of them...
which one to select?
02-08-2010 10:01 AM
If you right click on your labview 8.x/9.x "sound input read.vi" You can select which type the function shall give as output. This is in the select type option.
