The best one answering your question will be Greg McKaskle. I have read a lot of answers from him regarding multi threading, execution system and the relation between front panel and block diagram. I do this from my mind and if one of the other enthusiasts think my mind is wrong please correct me.
1. Execution system is LV internal mechanism to provide multithreading in nonmultithreading OSes. Execpt the UI Thread the execution systems are the same and the naming of them is just for convention. To allow different VIs have the chance to run before other VIs you use priorities. VIs with higher priority will run before other VIs. On multithreaded OSes this is mapped to OS threads. So DAQ Priority High will be mapped to a OS thread and DAQ Prioity Normal will be mapped to another OS thread.
2. One execution system has a maximum of 10 threads. It has 5 priority levels and each level has two threads. The number of threads depends from the number of priority levels which are used.
3. Maybe you can think of a execution system having 5 sub-execution system in one foe each priority level. But I think that's not the way it's implemented. I think each priority level is divided into 5 parts one for each execution system.
4. Th UI thread uses the Normal priority. It is only blocked if a VI is running with higher priority and only when it does not try to display something.
5. I don't think they are different in the way to use it. As I remember in LV 5.1 only a limited number of execution systems and threads are created at LV startup. You could set some setting in LabVIEW.ini and there was a VI to do it to activate the others.
6. Subroutine priority isn't really a priority. VIs not having Subroutine are compiled in a way that at each node the VI is requeue into the queue of it execution system and priority. This is done to allow other VIs to run and is the mechanism to provide multithreading in nonmultithreading OSes. A VI with subroutine priority is compiled in a way not to requeue at each node. This VI will complete its execution before allowing other VIs to run. This is a critical point when running on nonmultithreading OSes. From the sight of the execution system a subroutine VI has the priority of its caller. The User Interface thread has to deal with the GDI which draws on the screen, mouse and keyboard. It is much easier to implement a multi threading system with only one thread for such a task. And I'm not sure if each GDI is implemented reentrant on each platform LV will run.
Priotires within LV are mapped to priorities of the OS. If you open the task manager in W2k or XP go to the processes tab and select from View>Select Columns Base Priority you can see the priorites assign to the processes. Unfortunatly you cannot see the priorites assigned to the thread. You need something like Spy++ from the MS Visual Studio. The OS will run threads with higher higher priority first until there is no thread which want's to execute. Thats the reason you need to implement a wait in high priority VIs.
7. This article refers to LV 6i and the App Note to LV 7.1. I think the diference comes from a decision to change the implementation. The reason are blocking nodes like a CIN. Two threads for each will execution system and thread will allow to call a CIN and to run another VI in parallel.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
