some paper about FTP
Hi, I want to read something to learn about ftp. I want stablish a conection between my CRIO and my PC.
Thank you.
(3,132 Views)
What exactly do you want to learn? That is a very broad question. The Internet Toolkit includes a set of FTP VIs. If you want to know the low level details of the FTP protocol then a good place to start is the RFC.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,120 Views)
Hi thank you for answer. I want to learn about How I can transfer files from CRIO to PC and from PC to CRIO using FTP?
(3,100 Views)
Have a look at these links:-
http://forums.ni.com/t5/LabVIEW/ftp-files-from-cRIO-to-host-PC/td-p/980087
http://forums.ni.com/t5/LabVIEW/Copy-file-from-cRIO-using-ftp/td-p/1097546
Hope this helps.
Thanks as kudos only:)
(3,095 Views)
Hello Mr.farmcorp
Here is an example of what I belive you are looking for
https://decibel.ni.com/content/docs/DOC-15379
I hope it helps!
Luis Elias
NI VeriStand and HIL Product Manager
(3,070 Views)
Hi danil33, these links gave me a good idea about I'm looking for.
Hi lfelilas, I have checked the example.
Thank you for answer danil33 and lfelilas.
(3,056 Views)
