03-10-2010 10:58 AM
Hello friends
This one we cannot control. This will work asper the program which we wrote in the string.
Now I am trying to made or already made one is we can set all the parameters in the front panel. Now it is of final stage.
Just wait for it.
Thank you
03-10-2010 11:02 AM
03-10-2010 11:21 AM
Hello sir,
This is not a driver but we can control the FRA for their own purpose. I am trying to make this as a control driver. In my labview software IDE is not working or I didn't download any module for this purpose.
The property node is not required, I thought, i clear all the visa and also I closed the visa. so primary address setting is better in this case.
I cannot solve with higher timedout in VISA read and also in Scan from string palette..I tried in VIsa read 2S,10S, 20S etc. all the case same error it is showing( default is 2S). So I use clear message.
03-10-2010 11:36 AM
03-10-2010 11:44 AM
hello sir,
I don't know about the pre-standared termination scheme. (This by self study only). I never gone to inner parts of LabView.
I already tried with 1260 driver some months back. At that time it was showing some errors. I think it was in the
Initializing palette. I will try once again.
Thank you
03-10-2010 11:48 AM
The termination has nothing to do with LabVIEW. It has to do with the IEEE-488.2 standard. There is a management line on the bus called EOI (End Or Identify). The standard adopted in 1987 made the use of this line mandatory. Before that (or even later if a vendor did not care), the EOI may or may not have been asserted after the last data byte. A different scheme of terminating with CR, LF, or both may have been used.
You would of course need to modify the init function of the 1260 in order to recognize the 1250.
03-10-2010 12:05 PM
Thank you sir
thank you verymuch
I am expecting more and more from you, sir
03-12-2010 09:26 PM - edited 03-12-2010 09:34 PM
Hello everybody,Listen this!!! This is not a driver but we can control the FRA
Thank you everybody
thanks
