11-06-2012 08:31 AM
Or any relay for that matter.
11-06-2012 08:14 PM
11-06-2012 08:18 PM
If you use a DMM and when you send a signal, what voltage do you measure?
11-06-2012 08:21 PM
Like I asked before, you need something to drive the relay.
11-06-2012 08:29 PM
11-06-2012 08:30 PM
You will need an opamp circuit to increase the voltage since you are using the NIELvis board.
11-06-2012 08:42 PM
11-06-2012 08:59 PM
http://en.wikipedia.org/wiki/Operational_amplifier
11-06-2012 09:05 PM
@Tarmizi wrote:
I record the voltage of 1v. Is it very low. If it does, how do i increase the voltage? Thanks in advance.
once you have received 1vdc on your AI, then DO to a driver that is connected to your relay and external source...that should work
11-08-2012 09:05 PM
Ive created a program smoke alarm that able to receive signal from the smoke alarm and use that signal to send to the relay. But the thing is that the sending signal is forever on eventhough the receiving no longer receive. By the way im using NI Elvis2. How to solve this? thx in advance
