Jim:
Here are more information about the application builder:
Add Top-Level VI: top-level VI to the application. You must have at least one top-level VI. When you add a top-level VI, LabVIEW automatically includes all its subVIs and related files, such as menu files. LabVIEW also includes DLLs if the VI references the DLL using an absolute path. However, if you use the VI server to call VIs, you must manually add those VIs by using the Add Dynamic VI button.
Add Exported VI (Shared Library only): Adds an exported VI to the shared library. You must have a least one exported VI. When you add an exported VI, LabVIEW automatically includes all its subVIs and related files, such as menu files. LabVIEW also includes DLLs if the VI references the DLL using an absolute path. However, if you use the VI server to call VIs, you must manually add those VIs by using the Add Dynamic VI button.
Add Dynamic VI: Adds VIs that the VI Server dynamically loads.
Add Support File: Adds non-VI files, such as drivers or text and help files to the application.
I hope this helps.
Rudi N.
