12-03-2002 09:36 AM
12-05-2002 08:56 AM
12-09-2002 02:36 AM
03-18-2003 07:24 AM
04-13-2006 05:30 AM
I am using a DAQPad-6020E as well with Labview 8.0.
I am using AI Acquire Waveforms in a parallel VI to sample up to 32 channels at a time. With this VI, you can sample multiple channels multiple times. So sample 1000 samples at a 1000hz sample rate for example. When the parallel VI is finished, it saves the results in a global variable so my timed loop can read it and put them in a chart.
04-13-2006 05:32 AM
In addition to my previous reply,
Remember that the USB port IS the bottleneck because it receives packets of information. I have tried getting reaction times via the USB port, the delay through the port was over 20ms. This is because the data is buffered by Windows before Labview can read the data.
04-14-2006 11:41 AM
