single triggered acquisition on the scope timeout problems
Hello Everyone
I am trying to do a single triggered acquisition on the scope. I initialize my scope and configure the settings. I then
enter a loop at set the trigger level and then want to read a waveform from the acquisition. But, it does not seem to have a timeout.
It just reads the waveform right after I set the trigger level even if it did not reach the trigger level. I think it does not wait for the trigger.
Is there a way to fix this?
I am using a TDS 2024B scope and am using the drivers. I thought I could use the VISA Enable Event and use Trigger as the event type for the input and then
use the Wait for SRQ and have a timeout of 25000ms but it did not work. I receive an error saying:
Specified event type is not supported by the resource.
I don't know what to do for the timeout. Is there any other ideas I could use or am I doing it wrong?
I attached the vi. I am using LabView 2010.
Thanks!
Midna
(2,837 Views)
Accepted by topic author Midna19
Look at the example in the Tek library
=== Engineer Ambiguously ===
(2,818 Views)
Thanks RTSLVU!
I needed to change the timeout constant to fix it.
xxxMidna
(2,790 Views)
