03-13-2010 12:59 PM
Hi All,
I want to simulate induction motor online starting with Labview. I have installed labview 2009,with control design and simulation,simulation interface toolkit
03-13-2010 01:00 PM
03-13-2010 01:03 PM
03-13-2010 01:23 PM
Have you looked at the free online LabVIEW tutorials?
Introduction to LabVIEW 3 hour tutorial
Introduction to LabVIEW 6 hour tutorial
Also, there is a control design and simulation tutorial:
Introduction to LabVIEW in 3 Hours for Control Design and Simulation
Check those out...they should get you started.
03-13-2010 02:30 PM
03-13-2010 03:17 PM
First you said you want to simulate and induction motor starting. I don't know exactly what you want to simulate, is it modeling voltage, current, feedback loops, speed, torque of an induction motor? That is all calculations and has nothing to do with hardware.
Or do you want to actually start a real motor, which has nothing to do with simulating anything. If you want to start a motor, you will need a data acquisition card with a digital output or a relay output. With that you can drive another relay which can drive a motor starter relay.
03-13-2010 03:38 PM
Actually, I want hardware realisation of this, Just want to simulate first.
03-13-2010 03:52 PM
03-13-2010 04:04 PM
03-13-2010 04:30 PM
No, because I really don't know what you are doing.
What are you simulating? So far, all you've wanted to do is how to "simulate" turning on a motor. A motor is either on or off. So you have a boolean value that would drive a digital output which would drive a motor contactor/starter if you had any of that hardware. Since you don't, all you can do is put a boolean indicator on your front panel.
Do you want to simulate inputs from these sensors as well? Then put some front panel controls that you can adjust which you can later replace with the signals coming from these sensors.
