simulate arduino serial monitor
object : Simulate Arduino's serial monitor on Lab view
problem : I'm working on a graduation project of Interfacing load cell and arduino
I'm using an amplifier to the load cell signal, so I've to load the amp code to the arduino
everything is good with the serial monitor and I get the readings I'm seeking.
Can I simulate these reading on Lab view for further analysis ?
(3,995 Views)
I don't know what you mean by simulate but you can certainly read the arduino. Do a search for the LIFA toolkit or just use the VISA serial functions. There have been numerous posts on this subject and a dedicated community board.
(3,988 Views)
np dude,
I've tried serial write and read example that comes with Lab view and it worked
Now I can read from arduino but I've to scroll the results
do u know how to scroll the readings automatically ?
(3,967 Views)
You need to scroll the output. Here is the simple one
1. Right click on string indicator
2. Create property node for the same
3. go to Text -> scroll position
4. Wire +infinity.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,933 Views)
Thank you guys so much
it worked
really appreciate it
(3,903 Views)
One more thing guys
I want to calibrate the reading I'm getting from the string so I can represent it on graph or numeric indicator
I got the calibration equation
but the string to path array and the unsigned byte array is not working any help
(3,857 Views)
