07-17-2019 01:07 AM
i am facing an issue while logging data to measurement file/tdms.
i am sending a pattern of data from fpga hardware(fpga-ft232h-labview). i am getting same pattern but its is shifting.
as after every frame(512bytes) labview adding 2-4 bytes.
please suggest how to avoid this case/issue.
please see the snapshot attached. suggest me where i have to make correction.
07-17-2019 01:22 AM
Hi saikiran,
As you only show some images we cannot suggest how to prevent that problem.
It seems the "unwanted" data is already in the string you get from VISARead: check the data at the data source!
Maybe the problem is here: are you sure your "fpga hardware" is really sending just the data you expect?
07-17-2019 01:54 AM
yes.
fpga part i have verified using logic analyzer. its sending correct data only.
<<It seems the "unwanted" data is already in the string you get from VISARead: check the data at the data source!>>
data in string !?! as my last bytes are 0's but its giving highest value "118" of my pattern data after every 512.
can we refresh string after every 512 ? so i can get only sent data.
is there any alternative ?
07-17-2019 02:13 AM
Hi saikiran,
data in string !?!
Yes, in the string you get from VISARead:
Do you get any errors or warnings from VISARead? That would explain why you get "0's" as last bytes…
07-17-2019 02:37 AM
please see pattern .. according to that i will get "0" as my last byte not 118.
can we refresh/reset string ? .
iam not getting any errors nor warnings.
07-17-2019 02:53 AM
Hi saikiran,
To plot this "0" in your chart it has to be part of the string data you receive from VISARead. The chart does not "magically" add zeros to your plots: they come from your data source!
So you need to examine where that zero is coming from - this process is called "debugging"…
Again: which data do you receive? Does that string already contain those zeros? Did you even try to debug your VI?
The string is refreshed with every VISARead call - THINK DATAFLOW!
I didn't ask for the error list of your VI in edit mode.
I asked for the errors in the error wire coming out of VISARead: you need to implement some error handling in your code to even recognize errors/warnings from VISARead! (This also is part of good coding style and debugging!)
