sftp stopped working after duplicate IP addresses
Hello everyone
I am using Labview 2023, Windows 10/11 laptop.
I have two NI CompactRIO controllers 9xxxx.
I connected a windows 11 laptop to controller 1 and sftp worked fine.
I then connected the same windows 11 laptop to 2nd controller which had the same IP address and the sftp times out . The connect.vi times out.
I cleaned up the known_hosts files. Still it does not work.
Are there any other files that need to be deleted to make this work or do I have to re install Labview?
I have already changed the IP address of the second controller but, sftp still times out. It seems there is some file that Labview has created from connection to controller 1 that is causing the file.
Thank you,
HH
Message 1 of 1
(1,138 Views)
