setting the properties of a secondary axis
Highlighted
I made a graph with two Y-axis. Now I want to set the properties of the
secondary Y-axis.
In the property node of the graph only the primairy axis seems to be
available.
How can I acces the secondary axis ???
Hans Jaspers
(2,168 Views)
Hi Hans,
first of all
choose item Active Y Scale and connect to # scale (0 for example)
then you can set any attributes regarding this scale
then choose item Active Y Scale again and connect to # scale (1 for
example)
then you can set attributes for this scale
and so on
Mike Manzheliy
> secondary Y-axis.
> available.
> Thanks
> Hans Jaspers
(2,168 Views)
this works similar to the cursors, plot styles etc.
At first you have to select the correct axis with the
properties 'Active X Scale' or 'Active Y Scale'.
Martin
Martin Henz Systemtechnik
Dipl. Ing. (FH) Martin Henz
Walchensee Str. 3
70378 Stuttgart
Tel. ++49-711-5302605
Fax ++49-711-5058649
http://www.mhst.de
"Hans Jaspers" schrieb im Newsbeitrag news:8ugajd$cl9$1@news.surfnet.nl...
> secondary Y-axis.
> available.
> Thanks
> Hans Jaspers
(2,168 Views)
