04-03-2008 04:54 AM
04-03-2008 05:56 AM - edited 04-03-2008 05:57 AM
Hi Enrico,
i see no problem. First you set the size to zero, and then you set the value of one array element. I think it is ok i think it´s no bug. Wherefore do you need it?
Mike
04-03-2008 06:15 AM
04-04-2008 01:40 PM - edited 04-04-2008 01:41 PM
04-04-2008 01:58 PM
This is a bug. We should not allocate array elements for setting properties (other than value) on the element DDO. I could not find a request for this bug, so I filed one: CAR #101612
Jeff Peters
LV R & D
04-06-2008 02:11 AM
06-19-2009 09:34 AM
06-19-2009 10:14 AM
06-22-2009 10:21 AM
Sima,
A list of bug fixes for 8.6 is found in the LabVIEW 8.6 Bug Fixes document, searchable from the ni.com homepage. Look in there for the CAR# previously filed and referenced in the above post and you will find your answer
06-22-2009 11:51 AM
