set PHD 2000 pump infuse rate to zero
I wrote a small LabVIEW program to control the infuse rate of PHD 2000 pump. It works fine except when I change infuse rate to 0, the pump is still running at 0.01 ul/min. I was wondering if the pump treats '0' flow rate in another particular way or it is the format problem.
(2,390 Views)
Hi kwang,
did you check the pump's manual or asked the maker of these pumps?
The manual mentions some "min flow rates"…
(2,366 Views)
