09-11-2008 03:54 PM
does anyone know where i can find
serial port read.vi
open serial driver.vi
or serial.llb library that is the lastest version and it is for labview 7.0
i also need _serpup.llb that is the lastest version as well.
serpdrv
Solved! Go to Solution.
09-12-2008 07:25 AM - edited 09-12-2008 07:26 AM
Maybe I didn't understand your question, but in LV7 the serial read and write are using the VISA read & write functions located in the Instrument IO > Serial (sub menu) of the Functions Palette.
If you do a search under Help > Find Examples and enter the keyword serial under the search Tab, you should get 7 examples. The top two should be good for you: "Advanced Serial Write and Read.vi" and "Basic 2 Port Serial Write and Read.vi".
R
09-12-2008 09:16 AM
09-12-2008 12:40 PM
i think Dennis is right to the point. Man, is there anything you guys dont have an answer to?
but yeah. the current program i have call into serpdrv.
i believe that's the older serial functions.
i think the whole idea is to replace it because its causing us problem.
i dont know if it will be an easy task
09-12-2008 01:36 PM
09-12-2008 02:21 PM
09-12-2008 03:27 PM
thank you dennis! i hope the two llbs work for now..
09-15-2008 04:37 PM - edited 09-15-2008 04:39 PM
hi guys,
i am working on changing the serial function to Visa. but I am stuck at two locations.
what can i edit in these two vis so that i dont have to call out for OLD SERIAL driver and use VISA
can someone please help me. i am stuck here. thankyou
09-15-2008 04:40 PM
09-15-2008 09:08 PM
