Dan, thanks for your prompt reply. I'm setting the properties for the terminator on the VISA Configure Serial Port VI prior to writing the command string. I didn't realize one could not set it in transmit, only receive. I don't see the option you mention on the string control, maybe because I'm in LabView 7. On the Format and Precision tab, it's set to Hexadecimal, and the value I'm using is D (for CR). Can you be more specific? How can I set its properties for transmit, or is my only option to include it in the command string? Will the backslash cause problems in that case? Thanks.
