serial VISA framing error
LabVIEW 2014 is ending 5 bytes to a VB.NET 2010 program.
The VB.NET 2010 program is responding with 127 bytes.
115200
8 data bits
1 stop bit
odd parity
no handshaking
So, out COM 28 for LabVIEW and in COM 30 on VB.NET
All the data bytes are received, but getting framing error on LabVIEW VISA Read.
The jumper from COM 28 to COM 30 is a 4-inch "cable".
Any ideas?
(803 Views)
Bad cable?
The serial port settings on your VBNET program doesn't match your LabVIEW program?
(798 Views)
115200
8 data bits
1 stop bit
odd parity
no handshaking
Any ideas?
Framing errors are usually due to slightly mismatched baud rates.
IOW: Check all of your settings and try a slower baud rate...
=== Engineer Ambiguously ===
(768 Views)
