separate color in rows listbox
Highlighted
Hi all
How can change the color each row seperate of the listbox ?
Iskander
(1,910 Views)
Highlighted
Accepted by Iskander
Hi Iskander,
you can use the property "cell background color". See the attached example.
Mike
Message Edited by MikeS81 on 05-27-2009 09:37 AM
(1,899 Views)
Highlighted
What I understand is that you need to change line separation (between rows) color, don't you ?
In the menu, select "View > Tool palette" and then, select the paintbrush tool (I mean : click on the foreground box color, and select the color you want to use). Then, click with the paintbrush tool on line separation.
(1,895 Views)
Highlighted
I do not know if this is Rube G code. But anyway take a lock at it
Edit: Oops to late 😉
Message Edited by Coq rouge on 05-27-2009 09:41 AM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(1,894 Views)
Highlighted
Thanks all for the attention
Yours examples helped me
Best regards
Iskander
Message Edited by Iskander on 05-27-2009 12:48 PM
Message Edited by Iskander on 05-27-2009 12:50 PM
(1,857 Views)
