07-26-2011 06:25 AM
Dear all,
I have a Sensirion evaluation kit for humidity and temperature measurement, with selfmade visualizer; but I want to acquire data via LabView.
There is LV code for ek-h4, but not for ek-h5.
Has anyone developed code for ek-h4?
Of course, LV code for the sensor itself would also be very appreciated (sht21).
Any other suggestions?
Usuario
07-29-2011 07:46 PM
Usuario,
We have instrument drivers for the sht71 and sht 75. There is a discussion forum where another customer was able to tweak these drivers to work with their sht11 and a NI usb-6009.
http://forums.ni.com/t5/LabVIEW/sht11-and-ni-usb-6009/m-p/1629364?requireLogin=False
Danny Funk
Applications Engineer
08-01-2011 01:22 AM
Hello Danny,
Thank you, I had already seen the post about sh11 and 6009, this will be my second option if I don't succed, but preffered to check for ek-h5 or sht21 drivers.
Seems as there are no drivers available nor self-built .vi from other users.
08-01-2011 06:34 AM
I'm afraid I do not have an answer, however I would just like to register my interest in solving the same issue.
08-01-2011 11:15 AM
ADeller and Usuario
Sorry but we only have drivers for the sht71 and sht75. Therefore attempting to modify them is your best bet.
Danny Funk
09-06-2011 03:28 PM
ADeller and Usuario, Did you have any luck making modifications to enable a driver for the SHT21?
Danny F, do you know if any Labview drivers have been created for the SHT21 in the time since ADeller and Usario's posts?
I have the same need. Thanks.
09-06-2011 03:51 PM
SnowyEleven,
Drivers specifically for the SHT21 have not been created. All of our drivers can be found at the following link http://www.ni.com/devzone/idnet/. Take note that there is a spot to request a driver at the top of the page.
Danny F
05-21-2013 02:27 AM - edited 05-21-2013 02:28 AM
I have written a LabView code to retrieve temperature and humidity from Sensirion's SHT75 sensor, through their Evaluation Kit EK-H5.
The USB Dongle is in fact a modified version of Code Mercenaries's USB Dongle including a IOWarrior24 micro-controller, and a +3.3V power supply. It can be talked to using a modified version of the iowkit.dll developped by Code Mercenaries. This needed DLL is included in Sensirion's Viewer software (installer @ http://www.sensirion.com/fileadmin/user ... _V2.12.msi).
The code can be readily modified for other Sensirion sensors by modifying some commands in the sub VI's.
However, I still don't know how to read or write the "status register" of the SHT75 sensor.
09-15-2015 09:32 AM
thank you very much!
Works well with the Evaluation Kit EK-H5 and the SHT21 on LV2014 SP1
09-16-2015 02:31 AM
Sorry for the fast hype....
The Vi does not work with the SHT21.
Communication works but the conversion from the measured RH% and T values is not correct.
I did put in the conversion math from the SHT21 datasheet but it doesnt work either.
Probably the USB-dongle does need to recieve some other commands to work with the SHT21 but until now I couldnt figure it out.
Does anybody have another solution?
