sending a ascii #3d character
hi there!
for programming my datalogger, i have to send a ascii-character #3. how i
can do this?
best thanks for solutions!
greetings chris
(2,299 Views)
Hi Chris
If you are using 'format and append' or 'format into string' functions then '\3' in your format string will generate the
appropriate ascii char.
If all you want to do is to generate any ascii char from a number. I would then suggest you use the 'Type Cast' function
(Advanced\Data Manipulation), to cast a U8 to a string.
The final way I know how to do this is to use the 'Byte array to string' function.
To view the string you have generated, use change the string indicator to '\' codes display via it's pull down menu.
Hope some of this is helpful
Tim
Chris Herzig wrote:
> hi there!
> can do this?
> greetings chris
(2,299 Views)
