sending Json with websocket
I want to sen this JSON using websocket connection:
  "jsonrpc": "2.0",
  "method": "subscription",
  "params": "2A"
using this add-on: WebSockets Toolkit for LabVIEW - VIPM by JKI,
I can create websocket connection with the website that I want to communicate with,
and I can send normal string and receive,
but I can't send JSON data like this, to subscribe events from the site.
When I send this JSON data like normal string, the website doesn't deal with it as command,
anyone has an idea to do that!!
Thanks in advance
(755 Views)
Too little information to provide help. What is the API? Does the site send a response at all?
(675 Views)
Thank you for your reply.
Actually I think my example wasn't correct 100%.
I need a VI to open webSocket connection with some website,
and listen to events on that website.
do you have an example to do that?
I use the package named  'websockets' from JKI.
it does has examples to open websocket and send/receive string from the server,
but I couldn't see or modify an example to listen to event from server.
I read that I should send as JSON request to do that as I mentioned earlier  but I couldn't
I could do that by calling API from the server but I need to use webSocket,
I don't need to make many requests to get new data.
(646 Views)
