From the License Agreement:
1. Definitions. As used in this Agreement, the following terms have the following meanings:
E. "Authorized Applications." Means (i) those applications that you create with development versions of the
SOFTWARE that you have validly licensed (including such applications that you create with third party
software using real-time operating system components of the LabVIEW Real-Time Module and the
LabWindows/CVI Real-Time Module in accordance with the licenses for such modules), and (ii) those
applications that you create with third party software development environments and that utilize Driver
Interface Software, if such software development environment is supported by such Driver Interface
Software as indicated in the applicable Documentation for such Driver Interface Software. Notwithstanding
the foregoing, any application created with the SOFTWARE acquired under an evaluation license is not an
Authorized Application.
2. Grant of License
H. Evaluation License; Pre-Release Software. If you have acquired an evaluation license, you may install and
permit your employees to use the SOFTWARE on computers in your workplace for internal evaluation
purposes only. If the computers are laptop, notebook or similar portable computers, you may use the
The evaluation license is for your own internal use only.
Therefore, notwithstanding anything in this Agreement to the contrary, you may not distribute or transfer any
applications you create with the SOFTWARE under an evaluation license.
So, no.
