06-02-2009 10:11 AM
I used type def control of cluster in my main and subvi.
Due to some reason, I don't want to display whole things of cluster in the specific vi.
For example, a, b, and c variables are useful in the main_1.vi.
but only a and b are meaningful in the main_2.vi.
How to manipulate a cluster of type def in this case?
Do I have to prepare two kinds of type def and then connect two clusters manually using bundle and unbundle?
labmaster.
06-02-2009 10:14 AM
06-02-2009 10:25 AM
To my knowledge, the boarder of cluster (type def) is not editable.
labmaster.
06-03-2009 06:21 PM
Which version of LabVIEW are you using? I am using 8.6.1 and I was able to create a type def cluster and edit the size of the cluster box to show/hide different elements in the cluster.
06-04-2009 01:33 AM - edited 06-04-2009 01:34 AM
Solution:
The basic idea for Type Definitions
and Strict Type Definition in LabVIEW is that they are custom controls
(*.ctl file) that can be placed in any VI. When the *.ctl file is
changed, every VI that uses that control will also be changed which
eliminates the need to go change each VI yourself.
When a type definition control is used, LabVIEW ensures that the data type is the same anywhere the control is used. A strict type definition is more restrictive and LabVIEW ensures that almost everything about the control remains the same.
A Type Definition
can have a different name, description, default value, size, color, or
style of control (such as a knob instead of a slide), as long as the data type
matches the master copy of the control. A type definition only
identifies the correct “type” for each instance of a custom control.
The “type” does not include things like data range for a numeric
controls, or item names in a ring control. So if you change the data
range on a numeric control or an item name on a ring control that are
part of a type definition control, it will not change these
properties on all instances of the control. However, if you change the
item name in a type definition for an enumerated type (enum), all
instances change as well, since the item name is part of the “type” for
an enum. You can also use normal property nodes with type definitions
as you would with a non-custom control.
A Strict Type Definition
forces almost everything about the control to be identical, including
its size, color, and appearance. Strict type definitions are more
restrictive and unlike general type definitions, they define other
values, such as range checking on numeric controls and item names on
ring controls. The only flexibility to a strict type definition is the
name, description, and default value which all can be different for
separate instances of the same control. The only properties available
for a strict type definition control are those that affect the
appearance of the control such as Visible, Disabled, Key Focus,
Blinking, Position, and Bounds. For example, if you have a strict type
definition which is made up of a cluster of various controls,
properties for each individual control would not be available. Only
appearance properties for the overall custom control would be allowed.
Souce link:http://digital.ni.com/public.nsf/allkb/1B04FD6A11E6F17286256C6300588BFA
