select VI wont work
I have been exeperiencing the same issue for a while, I am using Labview 2010. I have Labview 2010 on a different computer and this function works. As an alternative to the problem I am following the same solution of dragging and dropping the VI from windows explorer. Any Idea why Select a VI is not working?
Mudda.
Message 11 of 20
(1,780 Views)
Mudda.
Interesting.....
What OS?  If this is a Windows OS What are your General Folder "click settings?"
"Should be" isn't "Is" -Jay
Message 12 of 20
(1,772 Views)
I am using Windows 7 OS, here are the folder options:
Message 13 of 20
(1,750 Views)
Well, I'm stumped. sorry
Next Taker?
Edit: Your on Win7 and still taking screenshots?  Check out the snipping tool
Message 14 of 20
(1,745 Views)
I did not use screenshot, I used the snipping tool to capture the pciture.
Message 15 of 20
(1,735 Views)
I had the same issue in LabVIEW 2013 and found out it cause by the "TEAM Viewer" thired remote application.
Try to close any other program that run in the windows background.
Message 16 of 20
(1,637 Views)
Thanks - Had the same problem and closing teamviewer solved it.
Message 18 of 20
(1,452 Views)
Closing teamviewer solved the problem for me too!  Thanks!
Message 19 of 20
(1,368 Views)
More specifically, it's most likely the TeamViewer file sharing overlay that is getting you in trouble.  Usually disabling just that feature will set things straight.SZAEp.png
Bill
CLD
(Mid-Level minion.)
Message 20 of 20
(1,356 Views)
