searching *.llb's
There is a Labview post for code that will search *.llb as directories:
Only problem is it doesn't seem to work?  For example what *llb is the "Blackman Window.vi" in?
Message 1 of 9
(4,768 Views)
Hey,
Maybe you don't be able to find the blackman window becaus you are running a LabVIEW Base Dev System, where this VI is not included.
Otherwise you will find it within the functions palette under Signal Processing>Windows
Christian
Message 2 of 9
(4,760 Views)
I have the full development system.  I tried running the sample code on vi's I know are there and it doesn't seem to work.  Also the problem is not finding the vi. in the pallet.  SS
Message 3 of 9
(4,749 Views)
Hey,
In the FDS it should be included so it seems that something has gone wrong with your LabVIEW installation. I would recommend to repair LabVIEW under the Add/Remove Software section of the Windows Control Panel.
BR, Christian
Message 4 of 9
(4,741 Views)
Where is it normally located in the Labview directory and in which dll?  But this still doesn't answer why I can search any existing *vi with the tool provided by NI.
Message 5 of 9
(4,734 Views)
I mis-typed, meant to say:
"Where is it normally located in the Labview directory and in which dll?  But this still doesn't answer why I can't search any existing *vi with the tool provided by NI."
Message 6 of 9
(4,730 Views)
I guess I'll answer my own question:  The blackman windowing functions are located under C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\Analysis\4window.llb
Message 7 of 9
(4,720 Views)
Hey,
Excuse me for the late response but I'm out of office this days. So as I can see you found the answer by yourself!
Christian
Message 8 of 9
(4,689 Views)
I have similar problems using window file search utilities can not look inside llb
The attached utility will create a folder in the parent directory of the llb file and add names of llb files to the created folder for example "C:\temp\LLB_Contents"
where temp had an .llb file.
Once the LLB_Contents folder is created by the utility, normal window search functions or programs can be used to locate files
Message 9 of 9
(3,212 Views)
