05-12-2006 06:10 AM
05-12-2006 07:41 AM
I am not sure if you want to decimate your 3000 to 100 data points or if you are extracting a particular set of 100 of the 3000 according to some sort of criteria?
Can you post your code with sample data? Remember to tell the forum what verison of labview you are using.
thanks
David
05-12-2006 07:43 AM
05-13-2006 06:17 AM
Dear Mr. David and Mr.Uwe,
Thanks for responding to my query.
I am not trying to decimate. My aim is to compress the data in to particular increment.
For example, I have acquired voltage data at 10 samples per second for four minutes. I have chosen 10 samples per second sampling rate to not to miss any event occuring during this test time other wise the rate of change in voltage reading is very slow beause of this when I look in to the data file I can see many repeatative data which is not important to my analysis. so I designed the VI to compress the data file with 0.01V increments. But the performance of my VI is very slow.
I'll post my VI soon.
Thank you
M.S.Senthilkumaran
08-19-2006 09:53 PM
08-20-2006 01:55 AM
08-21-2006 04:27 PM
