Thijs,
Use the "Spreadsheet String to Array" function (in string functions). Wire
it as follows:
format string: string constant containing "%s"
spreadsheet string: your string
array type: (empty) array string constant
delimiter: string constant containing enter ("\n" with string in code
display mode)
The output "spreadsheet" is an array with strings that can be wired to the
attribute node of the listbox.
Important notice: \n is not the same as \r ! If your string comes from a
..txt file, this can cause unexpected results!
Wiebe Walstra.
AIR technical Automation.
By the way, Thijs. If your in the Nederlands, maybe you'd like to visit our
annual LabVIEW meeting, PierVIEW. This also applies to the rest of the
group. Check out www.air.nl, and follo
w PierVIEW 2001.
www.air.nl
"Thijs Boeree"
wrote in message
news:3AB75ABF.75C8D18E@amc.uva.nl...
I have a multi lined string and want to put it as list into a listbox (i
did it with a for loop and the "i"attached to the line index of the
"pick line" vi) but now a have let my for loop know how many rounds it
must do! How can scan a multi lined strings for "number of lines"?
Regards Thijs
