scaling within subpanel
I have a subpanel and would like the vi inside the subpanel scaled to the subpanel plane is that possiable?
(3,527 Views)
Accepted by topic author Just_me1
Have you tried Vi properties--> window size--> Scale all object on front panel as the window resize.
Or "This vi" node--> panel proeprties.
(3,516 Views)
Thanks...
(3,496 Views)
However, it scaled all my objects but kept the fonts to my indicators the same
(3,479 Views)
Check this one: Panel resize event
Also you can try using "This Vi" property node.
LabVIEW Scalable Tabs to Control Separate Tasks on the Same Interface
(3,476 Views)
