sbRIO-9651 : FPGA RS-485 baud rate beyond 230400 ? Error -1073807330
I am using a sbRIO-9651 and the FPGA CLIP file in "Additional Peripherals"  it shows six serial ports Serial1 ... Serial6. The first four are described as "RS-232 Serial Port" and the last two "RS-485 Serial Port".  On Serial6 (RS-485) I have configured TX, RX and TX Enable pins.
In my .vi on the Real Time I can set my "VISA Configure Serial Port (Instr).vi" with a baud rate. A baud rate of 115200 or 230400 works, but the rate I want to use (256000) generates a runtime error.  "  Error -1073807330  VISA: (Hex 0xBFFF001E) The specified state of the attribute is not valid, or is not supported as defined by the resource."
I suspect the FPGA hardware is capable of 256k bps but I am not sure if this is a basic limitation of the NI UART IP block, or is just some setting I need to change to allow an expanded range of baud rates (?)
(3,467 Views)
Accepted by topic author jbeale1
The maximum baud rate for these serial ports is 230,400 bps, so it is a limitation on the UART connection.  In the manual you can find more specific information if you need it!  http://www.ni.com/pdf/manuals/376962c.pdf#page=8
Kelli Kravetz
Product Marketing Manager
LabVIEW, LabVIEW NXG, LabWindows/CVI, Measurement Studio
(3,425 Views)
Thank you for your reply. I thought there must be a manual, but I had not been aware of it until now.
(3,399 Views)
