10-21-2019 09:48 AM
And now try to ping sbRIO IP. Because before that you were pinging your PC IP via loopback (your PC has the same IP you were pinging, so it said nothing about connection to sbRIO)
10-21-2019 09:59 AM
Hi Sam,
Done ping the ip sbrio. But, I get the same error
10-24-2019 06:00 PM
I still cannot solve the problem
10-27-2020 07:41 PM
Was this issue resolved? I'm having the same problem today and it is with a system on which I have been using with a sbrio 9607. The new device just doesn't show up in NI MAX.
I love the forum, but all too often the issue goes private and we never see the resolution.
10-27-2020 09:10 PM
I troubleshoot the issue directly with NI support staff and they figured out that my board has a problem. So, I send for a repair (under warranty) & the issue is solved.
I suggest you contact directly with NI support staff.
07-20-2022 02:31 AM
For all future readers of this topic I would like to add:
When I initially connect the sbRIO to the PC (which is properly configured because it *can* detect other sbRIOs), the sbRIO-9607 still does not always appear in MAX.
I then have to reboot the PC and the sbRIO will show up after this.
