03-12-2010 09:54 PM
Hello
I need to know about the saving of a waveform in JPEG or in Excel or any other format.
Solved! Go to Solution.
03-12-2010 10:36 PM
If you want a picture then you can use the Get Image method for a graph and feed the image data to a Write JPEG File VI.
If you want numeric data then you can use the Write To Spreadsheet File VI. This does not create an Excel file. It creates a text file with delimited columns, but you can open it with Excel. If you absolutely want Excel then you will have to use ActiveX. Examples ship with LabVIEW, and you can find more in the Excel thread.
03-13-2010 11:10 AM
Hello smercurio fc
I dont need to save the front panel image. I need to save the graph as like excel chart. Actuall I want take printout of this for attaching the report. Get image will give a front panel image only. Is'nt it?
Any other idea is there please inform me
thank you for fast reponding
03-13-2010 12:37 PM
As mentioned on the link, it is a method of a control. You must not have read anything there. The very first line says "Returns an image of a front panel object." and then it says it is similar to the Get Panel Image method. It's pretty plain to understand I think.
If you want an example, just open the block diagram of Append Control Image to Report.
03-16-2010 12:09 PM
hello
Thank u for the idea. I tried with invoke node get image and saved as PNG file successfully.
Thank you, everyone
